Need help!!!
Need help!!!
While driving the King this morning I noticed my Svc Engine Soon light on. I pulled over and reset the Ecu by pulling the plugs out for a couple of minutes. Ok so the light went away. When I turn the engine off and start it back that stupid light comes on again. I have a couple of mods on the car basic stuff, AfcII EvcII, full hks exhaust and a Ultimate racing cat delete with the O2 bong. I need help any one with any Ideas?
Originally posted by kuniboy
did you play in the snow? and what do you mean by resetting the ECU by pulling the plugs out? Spark plugs?
its really hard to tell if you don't know the code. But check this thread out. it might help you.https://www.evolutionm.net/forums/sh...threadid=58631
I bet its a cat innefficeny code. O2 bung or not it will usually throw a code. Without the CAT the rear 02 will see a different temp. than with. Hence the SES light. I used to have this problem on my WRX, but you could do a resistor mod to the 02 harness for a fix. Not sure if its possible on the EVO, but probably.
