Parts for EVO 3 Motor Build Up !Please Help!
Hi
I have an EVO 3 and it has a blown motor and need some good performance parts................
I have Spun No.3 big end and has stuffed the crank. So a Rebuild with Good performance parts in on the cards.................
Parts List
Forged Pistons 8:1 comp .................... $1500 AUS (Nothing Over)
Forged Rods ....................................... $1400 AUS (Nothing Over)
Balance Shaft Replacment kit ............. $ ????
Camshafts Not Sure what brand......... $ ????
Garrett 30/40 600hp Turbo ................ $ 2000 AUS (Nothing Over)
35mm - 45mm External Wast gate...... $ 800 AUS (Nothing Over)
Ok Now this is a Basic list so far and any other Parts you can think of would be great...........................Also a Contact in the States Thanks Rhys...................
Parts List
Frankly, that is a whole lot of money for pistons and rods.
Are you going to replace the balance shafts, or remove them? I'd suggest removal. GO here for the parts you will need:http://www.vfaq.com/mods/balance-shafts.html
Originally posted by eldanoloco
Yeah I know Aussie money is different but is it that different?
I second that notion on balance shaft removal
Thanks Guys for the Info keep it coming................
The Balance Shafts have been taken out but who ever did it never blocked the dam oil holes. so need the removle kit to block thr oil holes........................
$1 Aus get me 75c US....................
Got any contacts for the rods and pistons?
Your on the wrong list. You Evo engine is basically a 2g Eclipse engine. might wanna try www.dsmtuners.com.
All your prices are ****ing rediculous. You don't need anything to block the fron balance shaft oil holes. Pull off the front cover, punch the bearing out, rotate them to block the oil holes, and put them back in.
razorlab
5165
Aug 11, 2024 07:56 PM
CORZA
Jun 19, 2015 09:28 AM
