Evo 9 turbo or Fp white?
Thanks. I'll order a gasket from them. I will doing 60k service myself so will be getting those parts too along with all fluids.
My friend will look over the tune and I'll probably dial it in myself using ecu flash.
I'm coming from Subaru platform so I have lots to learn.
He is local and is very reputable in subaru community. I will start learning finally and monitor/fine tune if need be. I don't think that tunes are ever 100% perfect as far as afr and such, so I might dial those in precisely, especially if going e85.
but I do agree with you. right now i'll be getting all the tools needed to do open source and start logging, also plan onto lowering boost by 2-3psi.
http://imageshack.us/f/834/img0141aw.jpg/
^ wouldn't evo 9 or fp white make same numbers on e85 at that much boost?
how does it feel comparing to stock turbo on street? does it feel more laggy or about the same?
hard to search them because it has to be 3 characters when searching. I think I'll go with 71hta
thanks for the pointer. It will take me a month or two (i wanna make sure everything is solid on the car first)
https://www.evolutionm.net/forums/ev...-fp-71hta.html
https://www.evolutionm.net/forums/ev...ock-motor.html
https://www.evolutionm.net/forums/ev...a71-3d-sd.html
AMS is 2-3hrs away from me but I don't want to go to them.
I'd buy 9 used. So as far as power curve for street use 71 feels similar to 8? I just don't want something that's too laggy or dangerous on stock block.
I wonder how much a tune is from shops near me. Think buschur is 4hrs away.
