what is the best turbo for 630hp to 700hp? 6262 6765 or 6766?
6262 t03 .82 housing 3" v band
6765 t03 .82 housing 3'' v band
6765 t04. .96 housing 3" 5/8 v band
6766 T03. .82 housing 3" v band
6766 T04. .96 housing 3 5/8 v band
which you recommend me for my new setup .. I have everything but I need to buy the turbo and I'm confused. I want run10.6 i got blue 1750cc injector porterd head doble pump buscher 272 hks cams etc.. street car
ANYONE who has experiance with these turbo please help me thanks
Whooopasss2 (May 25, 2021)
Any one of those turbos are capable of your goals... Typically you want the smaller turbo that will get u the peak power your looking for to reduce lag and give you a wider power-band unless its just a drag car. Have you considered fp hta82 or 86? They seem to be on top of the game, offering the total package: great spool, reliability, and power.
I would do 6262 for that power level and use the v-band housing and it will be a badass setup. The HTA86 is also a badass and will acheive that goal as well. The others are for more than 700whp.
I agree it is fully capable but that turbo is lazy compared to the 6262 and both can easily make 700whp. I like the smallest turbo possible to make the power. If the goal was 800+hp I would definately recommend the 6766. I cant wait to see what you do with those EFR turbos.
Why port the head but fit such low lift cams, and then add a big turbo with such a loose back housing? Not hating. It just seems like an unusual combo. Will this be going on a stock bottom end?
