Picked up 05 evo 8 and a few concerns
Looked closer and found that the Bottom seal on top of the injector was cracked and half gone so it wasn't getting a good 'snug fit' in the manifold when you tightened down the fuel rail mounting bolts.
Ran out of time to do another boost leak test so will do that tomorrow and check everything out again.
Quick question-How does a stock 8 DV hold up to 30 psi??
![Smilie](https://www.evolutionm.net/forums/images/smilies/smile.gif)
'05's were the worst when it came to throttle body seals, lol mine were barely there. They rob you of alot of power when they're leaking.
As far as your spark issue, I see your mod list is close to mild but why don't you give the bpr8es 1 step colder plugs a try?
From what I've read e85 is a little more sensitive to pre-ignition.
Haha i will! I guess i have a synapse laying around but i hooked that up and it was leaking.. So i should check that one out.
Stock 9 leaks at around 26 tho? crushed maybe 30?
The fuel map on it right needs work. I want to run that, 11.9-12.
part throttle/spool up- is like 10.7
![Frown](https://www.evolutionm.net/forums/images/smilies/frown.gif)
Boost leak test today went well. pressure tested it to 30 psi and all was good.
Synapse Dv had a broken seal in the flange where the UICP hose comes and connects with it. Replaced that and holds like a champ! Driveability actually is about the same. No part throttle surge. Just al ot louder than the plastic piece
Put some Stock evo 8 iridium plugs in.. Stock gap. Stock boost= No misfire/sputter
ohhh im sooo happy
. Going to get tuned sometime in the next couple days and can't wait and see what power she puts down!
![Thumbs Up](https://www.evolutionm.net/forums/images/smilies/smilie_thumbsup.gif)
![lol](https://www.evolutionm.net/forums/images/smilies/lol.gif)
Ian0611
50
Jul 6, 2016 11:50 PM
