Which oil to get from Royal Purple
Old Mar 17, 2012, 11:55 AM
awdturbo8's Avatar
Neither. There's much better oil out there than royal purple
Old Mar 17, 2012, 11:57 AM
n2oiroc's Avatar
Originally Posted by Hassan
I found here in the shop (Mobil 1 0w40 new life)
Is it the same u advised me
They use different names for different markets, if it says mobil 1 and full synthetic, im sure its good.
Old Mar 17, 2012, 12:01 PM
gotonefinally's Avatar
I use rp ,and thats the only oil I use ,never had a problem its all hearsay
Old Mar 17, 2012, 12:14 PM
DJAfterShok's Avatar
Originally Posted by TheBoz
I run RP XPR 10-40
I dont have any info about it breaking down fast, but sounds like internet rumor to me.
Not really a rumor when its been proven, In an actual lab FYI.
Ill lok for a few links to back it up.
Also, depending on what turbo you are using. Mobile 1 is garbage also.
Old Mar 17, 2012, 02:26 PM
n2oiroc's Avatar
Many mobil 1 oils are good, just the 5w30 and a couple others are crap.
Old Mar 17, 2012, 04:50 PM
My03evo's Avatar
Just because you never had a problem doesn't mean nothing, you could have run the cheapest supertech oil and I'm sure it would be fine but why use oil that isn't as good as others? It's proven in lab tests and it's better protection for when you don't have time to change the oil or it overheats or you run it hard and if you baby your evo you should have bought a honda
Also supposedly Mobil 1 is no longer 100% FULL SYNTHETIC, it's like a hydro-cracked base stock oil and group 3/4 base stock oil or something. Amsoil is I believe group 5 oil? I do know they took out all the good stuff like the zinc and phosporous (good for bearings) as per govt requirement to help lengthen the life of cat converters. For picture proof go on the fp turbo's website (forced performance) and they did a test with a brand new fp black turbo using pure mobil 1 oil and after some dyno pulls they took apart the turbo and found heat damage on the thrust bearing/washer....Why would you want to use that even with a stock turbo when you know it's not good enough for a different style turbo? Everybody says well it says to use mobil 1 on the oil cap and comes in corvettes and many cars from the factory but that's a pretty dumb reason in my book.
Old Mar 17, 2012, 04:55 PM
My03evo's Avatar
Also there are tests from people who sent in there royal purple oil samples and basically the results were that the oil is worn out and did not have much more engine run time left on it.....and it wasn't much run time on it in the first place.....Search if you want proof
Old Mar 17, 2012, 07:00 PM
Chef-j's Avatar
What other oil brands you can get from local?
Old Mar 18, 2012, 06:48 AM
Every one is entitled to there own opinion
Old Mar 18, 2012, 07:36 AM
BoostINurI's Avatar
I would not put RP in my neighbors lawnmower.....nuf said
Amsoil or Brad Penn only in the evo period
Mobile1 is watered down treehugger approved now....thus sucks!
Some industrial mobile and rotella oil will work tho...but a little harder to source.
Old Mar 18, 2012, 07:54 AM
gsrboi80's Avatar
There is soo much horse **** in this thread it is unbelievable. FP turbos needed those higher zinc phos levels in thier JB turbos due to the dissimilar metals in their bearing design. Not an issue in your stock turbo or pretty much any other turbo on the market PERIOD.
Again to those who think they are doing their cars a disservice not using Amsoil is just plain ignorance. Sad really
LSs1Power
Oct 28, 2016 10:14 PM
Emit_1
Jun 23, 2016 09:04 PM
fvaldes
Aug 22, 2014 11:13 PM
bluebyu34
14
Feb 28, 2013 08:15 AM
chr1smtz
26
Feb 11, 2012 04:52 AM
Quick Reply: Which oil to get from Royal Purple
