where to mount oil temp sensor.
i have Defi oil pressure and oil temp sensors mounted on the oil filer housing. but i had to remove the oil temp sensor for the FP turbo oil line that i'm installing. but now i don't have a place to mount the Defi oil temp sensor. i did remove the OEM oil pressure sensor and the Defi temp sensor does fit but it's very long and i'm worry it might block some passage. if i run a T block, where's the best place to do it. there's also an OEM oil temp sensor on the drain plug but that's not connected up. thanks,
There is a bunch of ways you can do it, here would be my personal route.
1) Weld a fitting to your oil pan, independent of oil drain
2) Put a T off one of your other fittings of the oil filter housing... you can also run a SS or kevlar -AN line off this if you want to relocate it someone else if you are worried about clearances to other parts off the housing.
Personally, I will be running a fitting off the housing with a SS line and a T fitting to mount oil pressure and oil temp sending units. I have the setup just haven't installed it yet.
where did you get the -AN line?
I know someone here sells them but it's $35 for a 12" line...I want like a 24" line so I can safely mount it where I want, but I have no idea where I'd purchase something like that OR what the correct fitting size is to go into the oil filter housing. if you could help with either of those, much <3 for you
By the source you mean the sump right? Honestly 25" of line is not going to make any difference in the oil temp reading, the accuracy is going to become steady state once you reach operation temps and it wont matter anymore... the time frame it will take to heat up that small volume of oil is going to be negligible to any limit to which you are trying to actually read.
The best source I've found to get fittings is speedwaymotors.com or pegasusautotracing.com
Pegasus basically has everything.... but they are pricey... I choose speedway over jegs... and I'm in Ohio so I can just drive to jegs when ever I want... they don't always have what you want in my personal experience, but they do have a lot of stuff too.
I'll make a quick how too for this for others because I'm sure they'd be interested.
This is my setup
The oil fitting for the housing is from 42draftdesigns (I didn't try to source it anywhere else because I knew they had it)... I do happen to have an extra one of these btw.
42draft P/N: 42-912 (they also sell a fitting set, this fitting with a 45deg 1/8npt to -an (I think speedway is cheaper)
I happen to have my receipt right here as I just got these in last week.
Speedway P/N:
617-1302 T-fitting 1/8npt
910-31845-4 25" SS -4an line (they also have kevlar too which is more flexible, I use it on my other car, slightly more expensive)
617-4025 femaile fitting adaptor 1/8npt to -4an
324-962304 45deg fitting adaptor 1/8npt to -4an
If running a oil temp sender, you'll need a T like I show here, because it has a probe on it for the sensor which will need to fit down the barrel of that fitting... a shorter T will not allow you to fully seat the sender into the fitting, I'll bottom out. (hope that makes sense)
EDIT: lastly find out what your temp sender fittings are, often they are 1/8npt.
the oil in that line is going to be static (not flowing), and also the line might cool the oil down some by the time it gets to the sensor. i haven't mount a oil temp sensor remotely before, so i don't know. but i've always try to mount it where there's a good oil flow.
i've decide to get a new drain plug and drilled it out. i couldn't find my tap, so ill have to get a new one tomorrow, but i think it's going to work fine, like the oem sensor on the drain plug.
Either way, I'll guess I'll find out soon enough... as I had a factory oil temp gauge too I know what the operation temps are according to that.
Have you ever ran a oil temp sensor? (I'm not trying to bash you by any means)
This is my setup
http://i1137.photobucket.com/albums/...s/IMG_3152.jpg
http://i1137.photobucket.com/albums/...s/IMG_3151.jpg
Speedway P/N:
This is my setup
Speedway P/N:
