which FP is best for 25psi on 91
So I heard the fp green is best for 91 fuel and could possibly produce more hp at 25psi than the red or black. Now the BB fp's are out, so I was wondering if the red is the new green. This is also my daily driver and will never see a different type of fuel nor meth. I have a built head, 1050cc injectors, and bolt ons (stock block) making 320hp on a mustang dyno. I'm wondering what hp the new green or red would get me too. Thanks.
^the truth. bb won't make the turbo spool any ealier in the rpm range, but it will spool quicker inbetween shifts. The green has been called a great pump gas turbo, but that doesn't mean it makes more power than other FP turbos on pump. Just pick the one you want according to how much lag ur willing to sacrifice for power. I went green from 10.5 VIII turbo, and miss the response of the oem turbo. I picked up about 50whp swapping only the turbo and tuning (I have crappy cams tho). If ur just looking for a little more punch for a pump gas DD, green is the way to go
IMHO get the RED, perfect turbo especially for 91 as the Green would snap to attention too quick and may get you detonation where as the RED holds torque MUCH longer up top and will make more power as it is more efficient than the Green.
There is lag, about 500 More than stock or so but your powerband will be increased an additional 1000 RPMs (Make power to 8K or more if you have the mods to handle it).
Get the RED, it'll also grow with you it is a 9 Second Turbo in JB form.
....bb won't make the turbo spool any ealier in the rpm range.. but it will spool quicker inbetween shifts..... Just pick the one you want according to how much lag ur willing to sacrifice for power. I went green from 10.5 VIII turbo, and miss the response of the oem turbo. I picked up about 50whp.... If ur just looking for a little more punch for a pump gas DD, green is the way to go
High_PSI probably has it right. I have read that the Green has too much torque down low and will probably ventilate your block. I had a JB Red awhile back and it was a great turbo. They have made many upgrades since I had my Red. The green is an awesome turbo also, had one of those too. You would need to keep your torque numbers under 400 though with the stock motor.
i personally like my red im at 26 psi on 91 octane, mines a journal red with over 30 k on it, making over 400 hp on straight pump gas. Always pick a turbo where you can meet or exceed your goals. Mine is an eventual 500 hp goal, so eventually i plan to go e85 and at least 30 psi, where ill hit my goal. A green might have more tq, but a tq hit wheres off and then its all hp, i like tq punch, but i like stayin into the seat with the hp haha
Yeah, another choice I'm considering is the CBRD bbkdbbB. Seems like it's comparable to the red and around the same price. Does the bb fp's require the oil feed line? http://store.forcedperformance.net/m...=Turbo-Upgrade
I just received a fp green about a week ago and now it's on it's way back to fp. Supposedly the turbo was bad. Anyways, I did a bunch or research for the turbo before I purchased it. I have a similar set up as your but my head is not built. I diceided to go green cause I really wanted to keep it dd and still have a kick. The red is a good turbo if you have plans to make more power in the future but in my cause I really didn't want or need it.
I feel that if your goals are 400-450whp and don't want to worry about maxing out the turbo and running a stock block then the FP green is for you. Doesn't matter if you go jb or bb, however the longevity of the turbo will be better with the BB, which is why it costs more. Anything over 450whp with room to grow then go with the fp red.
