Has anyone had Issues with Shep Trans
#31
MAYBE it's a staff change.... Sometimes good people leave replaced by cheaper, less effective staff. I'm sure Shep doesn't work on all his transmissions thus relegating the work to others OR just getting tired and bored of seeing the same damn transmissions all the time
![lol](https://www.evolutionm.net/forums/images/smilies/lol.gif)
#33
MAYBE it's a staff change.... Sometimes good people leave replaced by cheaper, less effective staff. I'm sure Shep doesn't work on all his transmissions thus relegating the work to others OR just getting tired and bored of seeing the same damn transmissions all the time ![lol](https://www.evolutionm.net/forums/images/smilies/lol.gif)
#35
I delt with both Jon at TRE and John at Shep.
Both experiences were great and touch wood, my trans, tc from shep have been great and my rear diff from TRE has also been awesome. Havent put them to the test yet but from driving around for the breakin, its been great! You cant expect anything but quality from either shop.... but mistakes do happen sometimes
As long as responsibility is taken where it is required, then all is good
But in almost all cases, companies will not see it as there fault even if it is and will somehow but the blame on the customer
(dont expect this to ever change either, its sad but true)
Chris
As a side note, I really do hope that both Jon at TRE and John at Shep do get there hands dirty on these drivetrain componets... they arent cheap, and the service and quality recieved should be flawless, especially speaking about their top tier packages... like the ones I bought... One can only hope
![Thumbs Down](https://www.evolutionm.net/forums/images/smilies/smilie_thumbsdown.gif)
![Thumbs Up](https://www.evolutionm.net/forums/images/smilies/smilie_thumbsup.gif)
![Frown](https://www.evolutionm.net/forums/images/smilies/frown.gif)
Chris
#36
Pull out ya trans and DIY thats my MO. These Transmission are pretty easy to repair, You just need a caliper, Mic and Torque Wrench. A total understanding on how syncros work and A press or a brass Drift, And a Call to Misu for the parts.
I blue Printed my trans and went a tad bit more on the preloads and had .001 endplay in the input. I did a little work to the Syncros to ensure smooth Shifting, i just took her out yesterday after it was all said and done and it shifts Amazingly, Total Rebuild cost me about 1k in parts but that is everything every single bearing every single syncro all the sliders and shift forks all seals and oil. Now i have a Strong built Trans with a quaife center diff and tighter preloads but not to tight as to bearings would wear down faster. I used a APP to find the bell curve for the bearing preloads it measures Strength,Flex under load of shaft and wear. Shows you how much preload to use to limit flex of the shaft and have the most life out of the bearing.
for the Tcase id rebuild that myself too, but i got a deal on a already built one with a quaife in it.
Also this wouldnt be my first rebuild, ive built T5 trans that have handled 750 Ftlbs on a SBC and 9 bolt borgwarner austrialian LSD rear ends that have seen 900 Ftlbs.
Its almost at the point where im ready to start rebuilding these for people on the Reg just to help out.
#37
![Confused](https://www.evolutionm.net/forums/images/smilies/confused.gif)
#39
Only parts i was shocked at the price at was the dam spacers for the bearings, those are actualy expensive they are about 15 each!!! i was like WTF, everything else is pretty much what you expect to pay for a syncro or bearing. Also id say to use AMsoil in it, that seems to be the best oil ive used and ive tried them all so far.
#40
sorry
it would take me about 3 days to rebuild your trans after i got it. And the 3 days is just waiting for the parts at my mitsu dealer. It would take longer [14 business days] and cost about $1400 more if you wanted a quaife Center diff, cause you would need the bearings and the speedo gear and the center diff comes from england
but most people dont do the quaife center diff cause the center diff is decent in the 5 speed, just the output tube.
I dont want people getting twisted. I am not mad at shep, i had a TC done by them 2 years ago, it look them 2 weeks like they said, and the thing gave me 0 problems "reason i wanted to do business with them again." I just dont like someone telling me somthing false. You tell me 2 weeks and it will be done at latest, i plan for 2 weeks. Its been 2 weeks not even a build sheet review yet and come to find out you might not have 4.11's now? WTF
#42
Chris
Chris
#45
Shep Trans
I have had several transmissions and Transfer cases rebuilt by Shep and never had a problem. Not all mine I have helped several Evo owners fix their car. I try to help out anyone that owns an Evo or a DSM. Just ask the kid that owns that Laguna Seca blue EVO. When you say the charges are different make sure you understand all of the charges that you may incur. The box is charge nobody accounts for shep will only take a tranny or TC if it is in his box. Mainly because of all the broken ones shipped to him before. So that is so much for the box and little extra for shipping for them. Also make sure you look at the break down of everything they replaced. The standard is for a standard set of fixes if they have replace something that is not normal you have to pay a little extra. Then also remember your shipping back to the shop. Shep has been a great company to deal with over the years. Sorry your experience was not.
