NEW PTE 6466 turbo pics.
Old Aug 5, 2012, 06:15 AM
  #91
batty200's Avatar
When the map sensor wire popped off if toy got some detonation it could cause the rings to flutter and cause a lot of blowby.
Old Aug 16, 2012, 06:33 AM
  #92
FL_SilverEvo8's Avatar
Why did you go with the 1.15a/r? Don't most people just go with the .82a/r? What would the difference be and is it more helpful to go bigger on that side? Did you have any boost creep problems with the 6466?
Old Aug 16, 2012, 08:47 AM
  #93
ETS Michael's Avatar
It's a twin scroll setup, so in order to get the same flow on the top end you have to run a larger a/r. The A/R is just an area ratio. T3 .82 and T4 .82 have the same numbers, but the ID is huge on the T4 setup. Add a divider in the middle and it's as small as a .63 a/r (faster spool, but restrictive up top) turn this housing into a 1.15 and it's like a .82 a/r down low and larger up top where you need more flow area.
Old Sep 5, 2012, 11:04 AM
  #94
cragg56's Avatar
Thanks for the info.
EvoDan2004
101
Jan 30, 2020 10:05 PM
EvoDan2004
32
Mar 15, 2016 08:32 PM
EvoDan2004
29
Apr 15, 2014 12:56 AM
EvoDan2004
19
Apr 3, 2013 06:30 AM
EvoDan2004
May 19, 2011 12:19 AM
Quick Reply: NEW PTE 6466 turbo pics.
