Brian cromer single stage valve springs and retainers with Gsc s2 cams help
Hey guys I'm new to evos and I just bought bc spring and retainers single stage and Gsc s2 cams. I was wondering if this is a bad combo. Should I get new ones with this be alright. I'm looking to do fullbolton meth and cams on stock turbo for now. I'm kinda on a budget. So the question is this combo safe ? Or should I not push it and get duals. Thanks
Are the duals superior I'd say so, will the BC spring and retainer kit work most definitely in your stock turbo configuration as the car wont be in the rpm range where it would matter.
If you ever go larger turbo and start using that upper rpm you'll know when you start tuning
ChicagoEvo9
48
Feb 24, 2017 02:21 AM
Black_EVO_MR
Jun 3, 2016 08:37 AM
