What is highest psi for stock evo 9 turbo?
What is the highest psi that an evo 9 turbo can handle? and what is the guarenteed blow psi that it will blow up on? Can it handle 30psi? with mods? I was just wondering, thanks.
Running 30psi all day long on E85. 25psi on pump and seems to hold it ok.
Kanovic, with appropriate bolt ons, you should be around 330whp on pump. Shy of 400 on E85.
There is also a thread about this. State your parts, and people with similar mods can relate.
I ran 30 psi on mine on 93 oct with no issues whatsoever,34 on racegas for track duty as it was the max i could get out of it with the wastegate closed shut and no boost source going to it,,it's mostly in the tune and supporting mods that will allow you to run that kind of boost safely.
