Exhaust leak question
I put my full race manifold back on with a new gasket. At 1st there was a noticeable leak. Sounded like a tractor. I tightened all the nuts back down. It got pretty quiet (no tractor sound). However when I use a piece of garden hose to check I can pick up noise (more than anywhere) under the 2nd runner from the left. Despite tightening the 3 nuts as far as I dare I cant seem to get it any quieter while listening with the hose.
I'm scheduled to be tuned on Friday at Buschurs. Will a leak get picked up while on the Dyno?
I
I
Did you reuse the old gasket or new oem one?
I guess if you torqued down all the bolts in proper order at proper torque specs, then I would remove the manifold and see if the flange is straight. Also, make sure the mounting points on the head are clean of any dirt, old gasket material or anything of that sort.
That's all I can think of. Maybe someone else will chime in.
^i dont follow what your suggesting the op to do?
op take the car out for a drive... if the car has horrible response such as slow spool up and horrible boost recovery ( in between shifts boost drops and turbo has to respool) then chances are you still have an exhaust leak. if you torqued the bolts to spec and you still hear a leak, first thing i would check is the gasket. with the manifold off take a straight edge and check the manifold flange to be sure it is straight.
Well I pulled the car out yesterday and let it run for a bit. I torqued a few of the nuts again once the manifold was heated up. It seems that the leak is almost virtually gone now. I don't want to do any pulls until I get the car tuned up. I swapped turbos from a black to a red.
^Do not do this! Adding silicone sealant on either side of the gasket will greatly increase the chances if not certainly cause a leak! You'd be changing the distribution of the load on the gasket, most importantly at the sealing area. Let the gasket do what it was designed to do.
Myszkewicz
04-06 Lancer Ralliart How To Requests / Questions / Tips
136
Oct 11, 2013 02:04 PM
