Exedy Carbon Triple Plate Clutch Disc Thickness
Hi Guys,
Ive done many a searches with regards to this topic however there was no confirmed answers as most people sounded like they were guessing and or never mentioned what it was when they found out from proper sources.
Now i also have friends friend who works at Exedy here in Australia and he said the discs are supposed to be 5.5mm thick? Now as much as i'd like to believe it. It really doesn't sound right as everything i have read has been saying roughly 4mm so its a big difference so if anyone could confirm whether this is correct or give me the correct info that would be great.
Thanks,
Polo
Thanks,
Polo
I knew i was getting the wrong info...
Goes to show even though someone works there don't always trust their word.
And just to clarify all three discs are supposed to be the same thickness? As i have seen some clutches have different thickness on the triple plate.
Any help please as i have purchased a clutch and was told by seller saying the clutch has life left in it and i received the clutch and the discs measure 3mm,1.9mm,3mm . Need to sort this out asap as i need to get the car put back together for a meet.
I would have accepted the clutch having 3.96 and 3.98 thickness left however 3.00 , 3.00 and 1.90 does not give me any confidence in having it fitted in as pulling it back out straight away or even at 50 -100 miles would be ridiculous as labour costs money and so does time. The clutch was not by any means cheap to begin with to even consider rebuilding it as the with the costs all added up i may have just as well bought a new one and it would have been cheaper.
Anyhow i have been able to get a hold of the manual and it says
MAX 4.2mm and minimum 3.2mm
Manual
Manual
WTT[MidWest]: Gauging interest/WTT RPS carbon-carbon EVO 8 clutch
powerdriver
May 23, 2016 09:16 AM
20valves20lbs
10
Nov 12, 2015 09:44 AM
