Compressor cover and turbine housing designs
There are a few different comp. cover designs out there. I mainly see the bullet style anti-surge (MAP and Precision use this), the 3 bar anti-surge cover (FP uses regularly) and standard non anti-surge. The HTA 3582 uses an interesting one but it seems (correct me if I am wrong) like the other 3 bar anti surge covers just with a longer inlet.
It seems that are a few different offerings in turbine housing designs. It seems that the TS turbine housing can be hit or miss from certain manufactures.
I noticed for caterpillar turbos that an aftermarket manufacture for comp and turbine covers had made some changes to the design in order to reduce/eliminate common failures.
There were excessive cracking or the divider wall (sounds familiar)....http://www.betterturbo.com/turbine.html and http://www.betterturbo.com/dividerwall.html
Also in the 3 bar comp covers....http://www.betterturbo.com/compressor.html
Obviously a different platform,but I wonder how this could help us. Seems like we are already using diesel tech and it to use on gasoline powered cars. We only in the past few years have turbo manufactures design turbos specifically for gasoline engines.
I am curious if anyone out there has had compressor cover failure. I know my FP Red comp. cover made it through the turbo failure. I know that the divider wall failure happens to often with certain castings. It would be nice to see a beefed up TS housing.
I had a GT3582 .82ar with the standard non-ported comp cover and it surged badly during spool up, especially at part throttle. It made the car buck pretty badly not to mention the strain on the turbo it would be causing. So I got the cover surged ported like the precision bullet style, surge was totally gone but so was alot of midrange torque, I actually lost 80whp at 4750 rpm from this mod which really sucks! I wonder how the FP comp housing compares, I'm thinking of swapping to a HTA82 to see if I can get that power back.
I had a GT3582 .82ar with the standard non-ported comp cover and it surged badly during spool up....I got the cover surged ported...surge was totally gone but so was alot of midrange torque, I....lost 80whp... I wonder how the FP comp housing compares, I'm thinking of swapping to a HTA82 to see if I can get that power back.
what ever caused your torque loss is reason your surge was gone. had nothing to do with cover.
I have noticed that the new GTX series is using the newer 4 bar anti-surge design instead of the three bar.
The EFR series is using the same 3 bar outlet as FP.
I have to agree it seems strange that you lost so much midrange over a comp. cover swap. I am sure that you did, but did you check for boost leaks? I have heard of people developing them where the comp. cover mates to the turbo due to the o-ring.
socalx_dsm
Jun 18, 2016 05:36 PM
APM Racing
EvoX 'For Sale' External Engine / Power
Mar 28, 2011 04:43 PM
APM Racing
Mar 28, 2011 02:58 PM
APM Racing
Jan 26, 2011 01:26 PM
