ARP headstuds install
so ive read a bunch of threads about installing ARP headstuds and though there is some concern i will be doing the 1x1 method. my question is from all the threads ive read it states to install your first stud till its tightest then when you go to install the nut you should torque it to a lower spec then loosen then torque it more then loosen then torque again to its appropriate final ft lbs rating. then go on to the next stud and repeat? just wanting to make sure i am understanding this correctly... any tips or tricks would be much appreciated
I have the L19 headstuds and torqued them a little more than most people do. Most people stop around 80-90 ft lbs. You don't torque the stud itself when you put it in. Just thread it in and use the proper allen key to screw it down but you don't need to tighten it too much. The nut you put on is what gets torqued down not the stud.
I think ARP calls for around 80 ft lbs so I would do 40 - 60 - 85.
sounds like a plan, thanks for the info
Rgraystone88
12
Oct 23, 2014 01:41 PM
EvoDan2004
56
Mar 15, 2007 05:46 AM
