OEM or Aftermarket harmonic balancer on a 4g64?
1 Post
Did the it come with one?
IF it didn't then..............
There is no shortage of 4G64's running around. First i heard of anyone inquiring about this.
Harmonic damper is tuned to the frequency of a STOCK motor. Can you run a stock damper on a modified engine? Sure you can. You can do whatever you want. Will a viscous fluid filled damper custom balance and dampen harmonics for your particular modified engine? Yes it will.
