550whp goal!
550whp goal!
i got a evo 8, stock motor with a few bolt-ons and i'm looking to make a 550whp daily driver on pump. here's what done so far... Halman boost controller, ETS turbo manifold, 3.0 02 Eliminator Downpipe & Dump, 3" perrin test pipe, 3" Greedy catback, 3"fmic don't know the name and ic piping. i also have on the side exeddy twin disk, ARP head studs, BC springs&retainers, and a blue gates timing belt. i was wondering what cams & turbo to use..
You won't make that on pump no way possibly high 400's. why not go with meth injection or e85 if youre looking for big numbers?
either that or look for a bigger turbo and cams
Bryan
550whp is a GT35 0.82A/R turbine housing set up
Needs cams of course and ported head.
Once you will port the head you will see that the MAF is out of scale (400+mmHg)
So you need to use race ECU and work with Temp sensor instead of MAF
That would be my suggestion
9:1 compression ratio will do the job
1000cc injectors and upgraded fuel pump is also needed
well this is what i came across so far...
i have new twin disk exedy or
used 100-200 miles triple disk exedy
ported head with hks beehive spring&retainers
hks 272
Magnus intake manifold with 80mm magnus tb
precision 880cc injectors
wisco pistons 9.1
eagle rods- i know, i know, but got them for free.. i'm gonna upgrade to some manley's soon
AEM ems v1
map down pipe w/open dump
ETS turbo manifold
3" fmic not sure what kind?
still working on turbo and seeing what else i can get
hks 272
wisco pistons 9.1
AEM ems v1
ETS turbo manifold
how big should i go? i figured that would depend on what turbo i used.. thats why i was waiting until i get my hands on one before i go crazy with injectors. i just pick up a AERO Motive stealth fuel pump
Get the biggest injectors you'll think you'll ever use to leave yourself room to grow. Even if you don't hit anywhere near the maximum injector duty cycle, it shouldn't be an issue if you get them scaled correctly.
I currently have 850s on the stock Evo 9 turbo, and I wished I gone bigger.
