clutch flywheel alignment pin?
Hi guys today i was driving and heard what sounded like bb's rattling in my tranny only did it for few seconds car was running fine. So today took off the inspection plug and there it was the alignment pin from flywheel to clutch. So i have a decision to make pull tranny go over everything put pin back in. Or drive it also what would cause the pin to fall out its a stock resurfaced flywheel with 8k on new clutch and resurfed fly.Thanks
Your clutch spins at speeds from 0rpm-7,000rpm. And then something that aligns it, help keeping it symmetrical, falls out.
I would say the next smartest thing to driving it without fixing it, would be to dump the clutch at 7k, No Lift Shift every gear that it makes it too, and then see where you're at from there
Randal
31
Oct 31, 2012 04:55 AM
