Top Mount 6466 from MAP Sneak Peek!
#34
Not yet. I'm waiting on quarter master to send my bearing so I can put the transmission back in. The kit is also going to require a radiator from an Evo 4/5/6. I need the motor mounts in to verify clearance using a thicker core koyo.
#45
BTW, the radiator is a CBRD ultra-slim with the upper radiator hose outlet moved up a little bit. I wanted more clearance than the Koyo/Mishimoto would give me. The CBRD radiator has the outlet normally sitting a little lower than those two. The clearance provided by having it moved up turned out to be absolutely necessary. If you plan to purchase this kit and use a CBRD radiator, be sure to tell him to move it up like mine!
