ATTN Omni map sensor users- reminder do not use the supplied o ring
Old May 23, 2012, 11:22 AM
boosted91t's Avatar
Just wanted to remind Omni Map sensor users to replace or reuse your o ring from the stock map sensor.
I have personally experienced a 100% leak ratio when installing the Omni map sensor with the supplied o-ring.
My solution to the problem- replace the supplied O ring with a 2.4 W x 11.8 I.D. O ring. It is a thicker o ring and ensures a leak free seal. Remember to use some sort of lubricant, don't just jam the sensor in dry.
I have had 2 cars come through my shop this week so far with boost leaks here.
Old May 23, 2012, 11:40 AM
20austin08's Avatar
good info
Old May 23, 2012, 12:41 PM
4g63evoeight's Avatar
where did you get the o-ring?
Old May 23, 2012, 01:53 PM
killerpenguin21's Avatar
how big of a leak is it? i used the supplied o ring not knowing any better, and have whacky fuel trims.
Old May 23, 2012, 03:04 PM
wrcRS's Avatar
Thank god someone else had this problem. I've gone through one that started to crack from my own mishandling (but was leaking prior to my hamfisted abuse) and the second one I got leaked as well.
I will try the o-ring you mentioned.
Old May 23, 2012, 06:26 PM
dangle's Avatar
Yeah I came into his problem last year. I ended up going to advanced auto and purchapsing the only multi pack that they carry and supplied was an o ring that fit perfect without leaks. I don't know the size of it but hopefully that helps.
Old May 24, 2012, 07:37 AM
boosted91t's Avatar
I picked up an assortment of metric o-rings. The size listed above worked the best. Napa/Harbor freight both good places for O ring kits
Enough of a leak to make a difference. Think throttle body seal leak.
Old May 24, 2012, 09:20 AM
interesting...ill see if i can pry the ring off the stock sensor without killing it.
Old Jun 6, 2012, 08:13 AM
boosted91t's Avatar
To the top again for the people who didn't catch this last time
Old Jun 6, 2012, 10:18 AM
i think i owe you a beer. i swapped over to the 40k mile stock o ring, and appear to have picked up at least 1 in/hg at idle. giving the trims a few more days to adjust and see where i get...but im already seeing better than i was.
Old Jun 6, 2012, 11:00 AM
Ian0611's Avatar
Thanks for posting!! I didnt know about this issue. I'll add it to the list of things I need to do if I ever go to work on my car again... lol
Old Jun 6, 2012, 01:49 PM
1badgsex's Avatar
ok heres a question for all the tuners out there ... can i just replace my stock map sensor with the omni one and be fine? im running hks vpro with knock amp so it uses both the stock map sensor and the supplied one from hks... im wondering if i can just replace it and still be ok tune wise anyone have any thoughts on this??
Old Jun 6, 2012, 02:48 PM
no idea if it will work with the hks, but to use it with the stock ecu you have to adjust the scalings since it is a wider range of measurement than stock. so no you cant just stick it in and have it work.
Old Jun 6, 2012, 04:54 PM
1badgsex's Avatar
yeah i read that a while ago u have to go in the ecu and adjust stuff but thanks for the info and help
Old Jun 6, 2012, 05:20 PM
JohnBradley's Avatar
I have installed over 75 of these and I havent seen a leak. I will check next time I boost leak a customer SD car though just to be sure. I will call Steve and bring it up though.
Aaron
Quick Reply: ATTN Omni map sensor users- reminder do not use the supplied o ring
