How Screwed Am I? Head Gasket or Rebuild Time or Option 3?
Old Oct 6, 2013 | 09:08 PM
  #61
PureDrivePerformance's Avatar
Originally Posted by MRfabolous
Bump i have spotted oil in my coolant like the op does that mean my headgasket is blown or on the way out it is also a cometic headgasket I always used evo9 head gaskets and never had a problem I switch to cometic now head is lifting I think.
It's blown. I can't think of any other way the oil gets in there. Why did you switch HG?
My (I'm the OP) problem was the timing was too high causing the head to lift. At your power level in your sig were you using the 9 HG too? What head studs are you using?
Old Oct 6, 2013 | 09:57 PM
  #62
MRfabolous's Avatar
thanks for the response i was using l19 head studs and a cometic gasket i actually installed one of a local evo for a customer of mine i do a lot of side work and was impressed with it so i decided to use one on my new build. so do i have to get the head milled down again, it never over heated. just wondering please point me in the right direction.
Old Oct 6, 2013 | 10:29 PM
  #63
I'd at least get it check for flatness at the machine shop.
Jan 3, 2014 04:14 AM
Oct 9, 2013 07:04 PM
10isace
16
Nov 15, 2012 03:56 PM
10isace
Nov 14, 2012 10:13 AM
10isace
10
Oct 27, 2012 10:02 PM
Quick Reply: How Screwed Am I? Head Gasket or Rebuild Time or Option 3?
