Help me unlock my MIVEC cam gear
Old Jun 10, 2012 | 09:27 PM
Anarchy99's Avatar
Originally Posted by ihockey1
thats what i thought, but at the same time john bradley said that sometimes you just need to disable the sensor check
https://www.evolutionm.net/forums/en...ses-light.html
I'd never do that. It was working perfect before the head swap so you know it works like it should. Take a pic of the camgears and valve cover and also the crank pulley and timing cover so we can see what it looks like at tdc
Old Jun 25, 2012 | 08:57 AM
ihockey1's Avatar
sorry it took so long, been busy at work
here's before i moved the gear back, ya i know these pics
and here's the after
Old Jun 25, 2012 | 09:47 AM
user 72082032's Avatar
Its 1 tooth further apart on the after picture.
Old Jun 25, 2012 | 10:12 AM
ihockey1's Avatar
ya the after means after i moved it back a tooth since the code its throwing says mivec is advanced so i pushed it back one but still getting the code so im stumped
ihockey1's Avatar
o i anarchy wanted lower cover and pulley pics ill try to get those too
Old Jun 26, 2012 | 10:58 AM
eric06ix's Avatar
To me, it looks 1 tooth off in the before picture, and after is 2 teeth off. It might be the angle of the picture though. I know with timing chains, there should be a certain number of links between the gears, does the FSM have the same for the number of notches in the timing belt?
Old Jul 8, 2012 | 01:12 PM
ihockey1's Avatar
hmm im going to bump this since im still stumped
Old Jul 8, 2012 | 04:23 PM
boostzealot's Avatar
The MIVEC gear is a little tricky to time in but its essential to be able to keep the tension on it, the tensioner pulley and the crank from moving while timing these in. That last pic of the MIVEC gear shows she's one tooth counter clockwise from proper timing. There will never be a time where the MIVEC gear will make itself a full tooth away from the exhaust cam while static. When you time them in you have to have the MIVEC gear to the right of the timing mark just a tad while making sure the exhaust cam timing mark on its gear is lined up. I say this because once you begin to tension the belt correctly it will tighten against the intake cam (MIVEC in this case) and will roll it back to the correct tooth by the time you have the correct tension on the belt. This is also before you release the pin on the tensioner. I hope that helps.
Old Jul 8, 2012 | 06:15 PM
ihockey1's Avatar
ok cool that's what i was looking for, thanks ill give it a shot. Also when you say move the gear to the right, should i use the marks on the cam to keep the cam at tdc, or does the whole thing move the right, as in the cam and the gear?
Old Jul 10, 2012 | 04:22 PM
You can actually leave the cam alone since MIVEC will use oil pressure to sort out the cam's orientation once rotation has begun. So all you have to do is end up with the marks lined up on the gears. Also what I like to do is take wood vise grips (plastic self locking type) and put them on the exhaust gear with the belt on it and lined up with the crank being at TDC. This tends to help the crank timing cog not move the gear so much when sorting everything out and tensioning the belt after you have the intake cam gear situated.
Old Sep 18, 2012 | 09:32 PM
Huy's Evo's Avatar
i dont know about moving the gear to another tooth but on my toyota corolla i had that code it needed a cam gear. it would make cold start rattle.. i mean like an over night cold start rattle. but make sure u are getting oil to the cam gear
hutch959
10
Nov 25, 2016 05:35 PM
EVOkeeper
Jun 22, 2014 08:43 PM
overdrive1
May 15, 2014 09:52 AM
Johnboy1065
12
Jan 14, 2013 03:43 PM
2006GSR
Apr 6, 2012 01:36 PM
Quick Reply: Help me unlock my MIVEC cam gear
