Help me unlock my MIVEC cam gear
Old Jun 5, 2012 | 07:06 AM
ihockey1's Avatar
I did a HG job a few months ago and ever since then ive had a rough idle and low vacuum, along with a P0011 code. So fast forward to yesterday when i decided to quit being lazy and take a look. What i found was that the mivec gear is at tdc but the line or mark on the cam is advanced. So my question is, can i push the cam back, if so how, since it doesnt seem to want to budge or do i need a new gear? Any help is appreciated, thanks
Old Jun 5, 2012 | 10:22 AM
ihockey1's Avatar
any ideas? i guess ill have to pull the gear and take it apart
Old Jun 5, 2012 | 11:47 AM
Anarchy99's Avatar
Your timing belt is off by a tooth, put it back one tooth on the intake gear and go drive your car again. Don't complicate the process more by taking anything apart
Old Jun 5, 2012 | 12:17 PM
ihockey1's Avatar
so the timing could be off even if the marks on the gear line up with the marks on the valve cover? ill bump it back a tooth and see what happens thanks ill give that a shot
Old Jun 5, 2012 | 12:18 PM
user 72082032's Avatar
If you rotate the engine backwards and forwards you should hear and see the cam pulley swinging back and forth from each stop.
Old Jun 5, 2012 | 01:08 PM
Anarchy99's Avatar
That's only if there's no oil pressure within the mivec gear. There is a check valve in the oil feed line from the block that keeps oil pressure in the gear for a considerable amount of time
Old Jun 8, 2012 | 01:45 PM
Anarchy99's Avatar
How did it work out retiming the engine properly
Old Jun 8, 2012 | 02:04 PM
ihockey1's Avatar
i was just about to update, not sure really, it helped but idle is still a little rough, vac is back to normal, but power isnt up and i still get the p0011 code so not sure what to do now
Old Jun 8, 2012 | 02:15 PM
Anarchy99's Avatar
What Ecu mapping is in the car?
Old Jun 8, 2012 | 02:47 PM
ihockey1's Avatar
Tephra V7, 90% completed tscomp tune
Old Jun 8, 2012 | 06:40 PM
Anarchy99's Avatar
Its in the engine timing or in the MIVEC maps. P0011 is MIVEC over advanced. Either your maps exceed 28.8* advance on MIVEC intake cam programming in the ecu maps OR your engine is out of time on the mivec cam gear.
What cams you using? stock?
Oh yeah and make sure your MIVEC solenoid IS PLUGGED BACK IN from the head swap you did.
Old Jun 8, 2012 | 06:54 PM
ihockey1's Avatar
checked the map and it doesnt exceed 28.8, so we're good there. The mivec gear is the one i bumped back a tooth but ill pull the vc and check again tomorrow, the solenoid is plugged in so i guess it has to be timing. Thanks for your help in trying to figure this out, i really appreciate it
Old Jun 10, 2012 | 07:35 AM
ihockey1's Avatar
small update, havent had a chance to check timing but yesterday i trashed her all day at the local autox and i didnt get the p0011 code at all, so i thought all was good since she seemed to pull a little harder and run a little better. Well i was wrong, code came back not 5 min after i got going this morning lol fml. Im thinking it is a phantom code but ill still recheck timing as soon as i get a chance
Old Jun 10, 2012 | 06:42 PM
Anarchy99's Avatar
Never seen a phantom p0011. I'm sure it's an actual issue
Old Jun 10, 2012 | 09:13 PM
ihockey1's Avatar
thats what i thought, but at the same time john bradley said that sometimes you just need to disable the sensor check
https://www.evolutionm.net/forums/en...ses-light.html
Quick Reply: Help me unlock my MIVEC cam gear
