HKS GTII 7460R -> external wastegate?
Gentlemen,
I'm a bit sick of fixing this turbo actuator, rod, flapper etc. Is there any way to convert this turbo to use external wastegate? To solve the issue once and forever? Anybody did it before?
Thank you!
Anton
Thank you!
Anton
the best fix is to install a mitsubishi 10.5cm hotside. any good turbo shop can machine the housing to fit. the wastegate can is not the problem. the adjustment comes loose because the exhaust housing is wearing out were the arm swivels in the housing.
this product does slow turbo spool. the runners are no longer separated. defeats the purpose of having a twin scroll bolt on turbo. really bad for choice for turbo that prides itself on ultra fast spool.
I'm currently running a "dual" wastegate setup with the internal wastegate and an external wastegate.
This ensures that the turbo still spools up quickly, and has excellent boost control with the external wastegate.
Overkill? Yes.
Does it work? Yes.
Jerry is assuming that you're leaving the stock internal wastegate flapper open.
Overkill? Yes.
Does it work? Yes.
Overkill? Yes.
Does it work? Yes.
the only justice for this problem is to replace the bearing and shaft or whole housing with mitsubishi hot parts.
twin scroll effect (fast spool) is lost when flapper opens or doesnt seat correctly in this case.
to use external gate you normally eliminate flapper or weld it open.
mike is using a properly functioning flapper in conjunction with external gate 02 setup. not sure why. I have never had a problem getting internal gates to control boost like they should. maybe he can explain in more detail what he was trying to achieve.
The problem I have had with internal gates is Slow response. I have adjusted them over and over but was never happy. On my old green(my old dsm) when I switch from the internal to external I gained 250rpms in spool. I was hopping running the internal and external set up would give me much better boost control.
I've ordered a flapper door for HKS built-in wastegate (34 mm from Forced Performance, some guys from Russia did us it successfully as a replacement part) and also FP actuator (old school, no nuts & bolts in the middle like HKS has). You've mentioned I also need to repalce bearing and shaft? Are they direct replacement from stock Evo IX turbo? Do you happen to know part numbers if you've did such a rebuild before?
P.S. Turbo is excellent. Works fine. When it works, damn
that wont work here. the problem with the hks turbos is the internal flapper no longer seals on the seat when used with the hks actuator. the bearing for the flapper shaft wears out prematurely. the actuator no longer pivots at proper angle so it doesnt seat the valve flat. many describe the problem as "warped arm" . arm is not warping but the effect is the same.
