What size injectors?
Hey guys! I'm going to upgrade my injectors soon, I'm swapping out to a Curt Brown ported exhaust manifold and a Evo IX turbo next month, with all the mods in my signature. I will be doing a 93 map and a 104 sunoco race gas map.
I want to leave some legroom for when I upgrade to an EF3 next year, what you all think? Great drive ability in mind please. I was thinking FIC 1250cc. I'm still on stock btw.
I definitely wouldn't skimp on the price of injectors. Go high impedance if you can. I think drive-ability is better in the bigger injectors. If you ever plan on going e85 you need big injectors. It's really all in what your plans are down the road and if you want to keep buying injectors to support later mods.
You're on the right track thinking 1250cc. 1450cc bluemax's would be my choice to keep it simple.
A bigger injector can always be tuned down to act like a smaller one.
Go too small on your injector choice this time around and you'll be buying a bigger set later.
Edit: You should ask TSCOMP about it if he's going to be doing your tuning still, he'd probably have a good recomendation for you.
I would definitely spend the money for high impedeance, if u get low imp on a 1200cc or up injector They will not idle real good on pump gas especially. I ran precision 1200s for awhile on e85 they were good except a little finicky sometimes with low rpm idle and part throttle stuff. I've got fic 2150's now....
h4ckluserr
11
Mar 15, 2016 06:30 AM
