Turbo Manifold advice needed
Old Jun 25, 2012 | 12:14 AM
ottoman's Avatar
Gents,
I have an HKS turbo kit on my evo 9 atm,
originally it had a 3076 on it..about 3-4months ago I replaced it with a GTX3076R
retaining the original HKS turbine exhaust housing
unfortunately the stupid manifold is made of papier mache. and keeps cracking on me.. it also causes very annoying resonation and vibration at ~3-3,500 rpm that buzzes through the whole car..
i'm getting tired of removing and getting it welded and re-installing it...
and now it's summer at over 90* F at night time and well into the 100's during the day..so its getting tiring real fast
i'm looking to replace the manifold..
the issue is..
I have an HKS WG,DP, turbine side etc..
Ideally i'd like to re-use as much from the kit as possible... and mimize cost.. (it was already expensive enough the first time round)
what do you guys suggest to be the most cost effective solution?
buy a full race manifold or similar, and Lop off the flanges and get HKS flanges welded on? would they compromise it's strength/quality?
ask them to make one for me with the correct flanges supplied?
i'm happy with the turbo and the WG and everything else.. and the pretty HKS heat shield. and I don't want to spend a fortune on redoing the whole kit.. nor do I have the stock turbo/manifold to go back to.
any suggestions ideas appreciated..
Old Jun 25, 2012 | 12:42 AM
jessmanEVO's Avatar
If i were in your position, I'd ditch that o2 housing and everything else with it and get an ETS kit. I've had my manifold on the car for over 2 years without a problem (knocks on wood.) When I upgraded to a bigger turbo from the 35r, I had to get a different o2 and dump tube fabbed up.
Old Jun 25, 2012 | 07:40 AM
ottoman's Avatar
so ur suggesting:
$1,200+ on a manifold
$300+ on a wastegate
then buy a new t3 turbine housing for the turbo
plus new downpipe, o2 housing, IC piping etc etc
close to 3k all just to use a ETS manifold?
does that make sense to you?
Old Jul 1, 2012 | 06:56 AM
acssa's Avatar
Jmfab
EVOII
10
Feb 25, 2016 11:09 AM
Hiboost
Jul 14, 2014 08:05 AM
240Z TwinTurbo
Mar 18, 2014 02:36 PM
Synapse
18
May 2, 2010 05:05 AM
Ekoy
36
Dec 17, 2009 01:49 PM
Quick Reply: Turbo Manifold advice needed
