disable p0031 via periph
any negative effects of disabling p0031, 0032 0037 0038 in the ecu? Im having problems with my o2 front o2 sensor, and I need an inspection, this is by means of using it for temporary reasons. I run full open loop any ways. But Im having trouble with my o2 sensor heater circuit. I have replaced the sensor twice back to back and it has problems. arr..
Are you worried about a CEL at inspection? Sorry every state is different, and in my county in GA we don't have inspections or emissions.
If so, you can easily just pull the bulb for the CEL. and replace it when you leave the station. I know in TN they want the cars to be running for at least 10 minutes before you show up anyways to check the emissions so they won't even catch if the CEL lights when you start the car.
no the code is stored in the ecu. I dont know what the heck my car is having a problem with. Ill have to test the wires to the ECU maybe I f'ed something up when I put my map switch in.
I need to make sure the ECU wont show the code. But I also need to make sure that the car is safe to drive and that no il side effects will become.
