Burning Oil
Burning Oil
I noticed my car burning oil its really excessive. It burned around 3qrts of oil at around 700 miles but, it only burns oil when in turbo. I noticed it leaves a stream of light grey charcoal smoke like a jet when I'm in boost and after boost it smokes until it burns off then it stops. It does not smoke at all in idle or when driving out of boost. I don't think its the rings if so it would smoke all the time even when idle so I'm thinking it's a valve seal or something. I had a leak down test and here are the numbers of the leak down test. Any ideas on what it could be? Any help would be greatly appreciated.
170 184 175 180
2.1L 4G64
AMS 2.1L Pistons
AMS 2.1L Drag Crank
AMS Specs Rods
AMS CNC Race Head
AMS Intake Manifold
170 184 175 180
2.1L 4G64
AMS 2.1L Pistons
AMS 2.1L Drag Crank
AMS Specs Rods
AMS CNC Race Head
AMS Intake Manifold
[QUOTE=Maddball;10263352]I noticed my car burning oil its really excessive. It burned around 3qrts of oil at around 700 miles but, it only burns oil when in turbo. I noticed it leaves a stream of light grey charcoal smoke like a jet when I'm in boost and after boost it smokes until it burns off then it stops. It does not smoke at all in idle or when driving out of boost. I don't think its the rings if so it would smoke all the time even when idle so I'm thinking it's a valve seal or something. I had a leak down test and here are the numbers of the leak down test. Any ideas on what it could be? Any help would be greatly appreciated.
I had same problem on mine 1-2 qrts per 1000, maybe less, found to be blown valve seals, two of them on exhaust side..... if your turbo is good and u dont have any sever leaks around the engine, i would recommend to took seals next... let me know what you come up with
[QUOTE=Spirit evo 8 MR;10263548]
Thanks. I definitely will let you know what I find.
Thanks. I will definitely check the seals on it. Everything barely has 3000 miles on it. I think I'm going to build a 2.4L Long Rod. I need more torque and quicker spool up. I may keep the short block as a spare or sell it and that's when I will get the seals checked.
Let me know your findings when complete. By the way how do like the 2.4L LR?
Yes, I agree with you on that. I have an AEM that I will be removing and going back to the stock ECU but mine is not a DD. Also checking the oil constantly is a royal pain, and as you said you really don't get to enjoy the car you have to ride around with a few quarts of synthetic oil in the car and that can get really expensive.
The motor should be in the car at the end of the week for break-in hopefully, and I will keep you posted.
Yes, after taking it to Greg of UCS Performance and doing a compression test one cylinder was low on compression and another was slightly low. I went back a few weeks later and Jason took off the head and we noticed that it was wet around the head gasket as well as the valve guides were wet. When checking the cylinder walls there was some pretty noticeable indentations in the cylinder walls that you could feel. Not sure what it was from honing/boring. So I ask UCS Performance to build me a new motor fresh block and send the head out to get new valve guides and seals etc., etc.
Sucks to hear about your motor. Hopefully you'll have better luck with the new one. My motor still burns oil, its just a little over 5k miles now and i still have to fill it quite often. No smoke at idle or wot that i can tell, but my dipstick keeps poping out during wot. Compression test was 180 across all 4. my 2.4LR shortblock was purchased off a member on here and everything was installed/broken in/tune by reputable shop.
I had the same problem with my dipstick with the old motor. What I did was placed a little screw halfway into the plastic part of the dipstick. I placed a hose clamp on the dipstick insert and tightened it and stretched the spring from the hose clamp up to the dipstick screw and it stopped it from popping out.
onlynamenotused
15
Oct 13, 2018 11:48 AM
stanlsha
22
Dec 30, 2012 09:13 AM
