ACD Issues
ACD Issues
hey guys i have this issue with my ACD system, my ACD lights on dash come on after car runs for few minutes, does not matter idle or driving... i've noticed that it started happening after it got warm and it got worst as it got hotter outside. i did several things to it, i completely bled the system with the diff nipple and ignition start/ gas paddle way, replaced all the fluids in the trans axle system, front, back and the trany itself just in case. what would you recommend to do next?? and is it safe to drive with lights on?? for now at list.....
Thanks for Help ahead of time guys
https://www.evolutionm.net/forums/ev...cd-lights.html
https://www.evolutionm.net/forums/ev...code-82-a.html
https://www.evolutionm.net/forums/ev...any-ideas.html
https://www.evolutionm.net/forums/ev...ts-coming.html
https://www.evolutionm.net/forums/ev...l-pay-you.html
^^About 1 min of searching. ACD Rebuild stuff should start being stickied. Seems very common these days.
Mine is shot as well. Rebuild kit on the way.
If bleeding doesnt fix it, its most likely either the pump housing or press sensor.
Check these guys out for rebuild. http://www.acd-tuning.com/
Or chance it and get a used pump <<not recommended
you can drive like that... no problem.. you can even drive around without the pump..
superkizuna
Oct 18, 2016 03:13 PM
