megan 02 housing vs stock 02
As far as the megan o2 hosing helping... lets just say if your on the stock housing your turbo isn't maxed out.
I saw pretty good gains going from my stocker to a megan. I did some mild port work to it around, well, everywhere lol. enlarged the merge hole a little, also made the main part where it bolts to the dp as large as possible without sacraficing strength. Its well worth the $ and 3 hours to install. Just do yourself a favor, take the radiator out lol. It helps a TON!
Silly question, but would installing a Megan O2 housing require any retuning? It seems like that is one of the few parts that could be installed and wouldn't need any retuning.
FYI.. I think I'm going to have a Megan O2 housing for sale here shortly.
Really depends on your setup. Im running ~32 psi with hks 272 cams, stock 8.5 turbo, and e85 (+supporting mods) and I leaned out almost a half a point just with the megan o2 housing vs the stocker. Also took a little more timing but that is really up to you. If you want to see the most, a retune is a good idea IMO
