Turbo/exhaust setup questions
Trying to figure out where to get a down pipe for an HTA35R .82 A/R T3. The only place I have seen T3 flanged downpipes that arent V-band is full race and they want $900 just for the turbo manifold. Also a setup question since I am not near the parts or car.
Have HTA35R with T3 3" 4 bolt inlet hooked to custom tublar mani fold with tial 44mm external wastegate and dump. Am I not running an o2 housing, also how is the downpipe hooked to the turbine exhaust? Been looking around for about an hour and cant find the info I need. If need I will buy a flange to hook to turbine outlet and get a custom downpipe made, but as noted is this the correct setup and is there suppose to be an o2 housing in there or does it not matter. Never run anything but stock turbo before.
Build will be FP HTA35R T3 4 bolt .82 A/R, T3 tubular manifold w/tial 44mm wastegate and dump tube, BR2.3L RPM, JAM built head with supertech dual springs, BR BF 272's, Walbro 440LPH E85 Pump, ID 2000's injectors, AEM EMS, 65mm TB, ported intake mani, 4" ETS intake with speed density, 4" ETS FMIC, ETS lower and upper IC pipes, A/C delete, and all supporting mods.. should easily be a 800+HP car with right turbo but will see mostly street time and want it to be reliable so probably be running between 500-600
thewickerman
121
Jun 14, 2016 07:44 PM
240Z TwinTurbo
Mar 18, 2014 03:36 PM
walker992
May 27, 2011 01:56 PM
