bigger compressor wheel in 8 10.5 turbo?
The only significant difference between the two turbos that you mention is that the IX turbo has a larger, more efficient compressor housing. The center sections are the same. The turbine wheels are the same. The turbine housings are both identical 10.5cm pieces. Oh yeah, there is a minor difference with respect to backing plates and diffusers on the compressor side.
i agree it makes sense then, i had bought an 8 turbo from a guy who told me that it had the 9 wheel put into it with the 10.5 hotside...does this all sound normal, only reason i ask is, if u look at the turbos side by side there is a huge difference
Sign me up
post pictures. sounds like you dont really know what you have
Evo 4-8 are the same, evo 9 is different.
The bearings and internal components are the same.
As you mentioned the compressor cover and the backing plate is different, but the backing plate is part of the centre core
ohmohm
Jan 21, 2014 05:11 AM
adcgn45
20
Jul 24, 2010 10:18 AM
