AMS 2.3 Build Fuel Question
I am just about done with my AMS 2.3 build but I had a question as far as break in with injectors. I put down before 350whp on stock injectors but I sold them and got HF boomba fuel rail and 1050 infectors. Do I need to put back my stock injectors to break in the motor so I dont run too lean or will I be fine with the 1050 injector for my break in period of the motor before i get tuned?
Huh?
As long as you have injector size compensation in your ECU program, you'll be fine.
If you don't, don't try to start the car! The ECU will compute your fuel based on the assumption that you have stock size injectors. In fact, your motor will be getting twice as much fuel per pulse as your computer thinks it's giving the motor. The result will not be lean -- it will wash down the oil from your cylinder walls pretty quickly, and run very rich if it runs at all, because it's getting twice as much fuel as it should...
im in the same boat as you, im changing to ID1000cc injectors, once im done with my build im towing it to the speed shop to tune it just so i can drive and then after my 500 miles im going to take it back for the final tune.. mabe you can try that.
Ian0611
50
Jul 6, 2016 11:50 PM
awhit17
Sep 19, 2015 02:38 PM
Ian0611
33
Mar 20, 2014 08:17 AM
Evokid03
50
Nov 12, 2009 04:44 PM
