Need advice: Tial 44mm wastegate setup with HKS EVC Boost controller
Hi,
I have been searching on the best way to set up the Tial 44mm waste gate with the HKS evc boost controller. Attached is the diagram that HKS recommends.
Here, the Out line from the stepper motor goes to the TOP of the wast gate. And the In line of the stepper motor is tee'd with the Bottom port of the waste gate and a boost source Pre-throttle body. The other port of the stepper motor just gets a Vac/boost source from post-throttle body location.
I assume all the other ports of the waste gate will be plugged in this case??
But TIAL on their website gave a diagram that says a bit otherwise? Or am I understanding a bit wrong?
Do I need to Vent any port on the waste gate?
Advice / Inputs please..
While on the other hand, for actuators, the EBC doesn't let the air pressure reach the actuator.
Which method will be better? Can I just treat the Tial Wastegate as an Actuator, and connect the lower port only, plug the lower ports and vent the top ports? Just like an MBC?
FS[SouthEast]: Mitsubishi Evolution 8 Apex Silver 1k on motor, 512 whp
steveliu30033
For Sale - Cars For Sale
Feb 21, 2017 11:00 PM
808boost
Oct 4, 2013 07:57 PM
