2.0 156mm Setup or 2.3 Stroker
Old Oct 24, 2012 | 10:10 AM
masonh's Avatar
Hes referring to full boost/spool. Not starts to spool.
thank you.
i forget some people here are still pretty clueless.i didn't even realize some guys thought spool means starts to spool,haha.
who runs a 6765 at 22psi anyway?
Old Oct 24, 2012 | 10:11 AM
Graphic's Avatar
2.4 w/ FP HTA GT 3582R or 86 if you don't mind the lag
or
2.4 w/ BorgWarner EFR turbo.
I'm on a 2.0L which is awesome case it's in expensive, but if I did it again, there would be no question about going with a 2.4L and recovering some of your money by selling your bottom end.
Old Oct 25, 2012 | 03:28 AM
2006GSR's Avatar
Originally Posted by masonh
thank you.
Unless I miss read his post. It says won't spool till 5k rpm.
What's wrong with 22psi? I maxed out my 1000cc injectors so we had to stop there.
Old Oct 25, 2012 | 06:03 AM
1d10t's Avatar
I bet you have a single walbro?
Back on topic
I lean toward higher rpm powerbands, so I'm opinionated.
But for roll racing, as youve described, I'dstay 2ltr.
The 2.4 is cheaper, but the mechanical timing isn't the same and
You should machine for oil squirters on a street car, with or sized bearings.
The 2.3 is a great setup too, especially for the street.
Old Oct 25, 2012 | 06:37 AM
Migsubishi's Avatar
Originally Posted by 2006GSR
LOL what did i just read!!!!
Lmao, The guy is clueless, you can tell he lacks experience using both engines...
I will never in life build anything short of a 2.4 hta86 or 6466 combo and even though I would never turn down a dig race, I prefer to roll race on the street, less shock on the drivetrain. Most street races never max out 4th gear anyway and my stroker is set to rev to 8700 if need be.
Old Oct 25, 2012 | 09:36 AM
2006GSR's Avatar
Back on topic
Yup single 255 and a inline Bosch o44. I wouldn't say the injectors where maxed out but the IDC was around 90%.
I have over 6k miles of daily rape on my 2.4L with out oil squirters. No problems what so ever.
Old Oct 25, 2012 | 09:40 AM
2006GSR's Avatar
The 2.4 is the best bang for the buck for a street car IMO. It's effortless to drive the car with ac on and full car of people and full tank.
Old Oct 25, 2012 | 10:28 AM
masonh's Avatar
i guess you really have to spell it out for some people.obviously full spool.
maybe you can explain it to me since you are so knowledgeable?why do all the race cars still use 2.0 motors?
Old Oct 25, 2012 | 01:39 PM
1d10t's Avatar
It's a mute point to argue anymore. I'm surprised this thread isn't closed, with talk of street racing.
From here, op, I recommend checking out the dyno results thread. Peep some power curves, and mod combos.
Also I encourage you to check out the drag racing topic. Fastest times/motor/turbo, some experiences.
There are good examples of both blocks making power and being successful. Different schools of thought, you can say.
GravityKnight
21
Mar 2, 2019 01:30 AM
R/TErnie
26
Sep 23, 2017 04:42 PM
SBR INC
Nov 26, 2016 07:39 AM
Ckeesee12
Feb 6, 2016 07:50 AM
Strm Trpr
16
Aug 10, 2009 07:32 AM
Quick Reply: 2.0 156mm Setup or 2.3 Stroker
