Evo 8: JUN 272 vs S2, if cost was no issue
Old Oct 25, 2012 | 07:06 PM
EVOlunchbox's Avatar
I've had the Juns in for 5 years now and will not change them.
dineshblack (May 17, 2018)
Old Oct 26, 2012 | 01:50 AM
Ted B's Avatar
Originally Posted by EvocentriK
So if the stock head can't respond to lift over ~10.5mm, any power differences between cams with >/= 10.5mm lift is really just based on effective duration and valve timing? Or is that over generalizing?
Flow data I have from four independent sources reveal that with a factory ports, once the intake valve is 10mm off its seat, it approaches 99% of its flow potential. The same point is reached by 9mm on the exhaust side. That being evident and all else being equal, ramp profiles and effective duration would represent the most significant differences.
Old Oct 26, 2012 | 12:01 PM
JohnBradley's Avatar
The thing to keep in mind is not all Evo heads are created equal even when stock. Some are even worse than that I am sure.
10-80-10 rule.
Aaron
Old Oct 26, 2012 | 06:00 PM
Liqquid's Avatar
I'm running some of Greg (GSC's) Jun272 replicas, and have been tossing around the idea of S3's.. just not sure yet as the powerband is pretty nice on the street with these.
side note: If my car trapped what yours does, I wouldn't change anything either
Old Oct 26, 2012 | 06:05 PM
Liqquid's Avatar
Originally Posted by Freddie@Spec-Ops
I went from the GSC Jun Replicas and swapped for a set of S2s and picked up nearly 30 HP on my 2.4... take that for what it is worth...
Old Oct 26, 2012 | 08:00 PM
Craig King's Avatar
Neither.
Kelford 272s.
Old Oct 27, 2012 | 05:54 AM
jasnm21's Avatar
Originally Posted by craig king
neither.
Kelford 272s.
BF272s
Old Oct 27, 2012 | 05:57 AM
Migsubishi's Avatar
Please read the title to this thread and stay on topic.
Old Oct 27, 2012 | 07:39 AM
Liqquid's Avatar
just out of curiosity what was done to the cylinder head, was it ported mildly something more aggressive? Also, do you recall what happened to the powerband, as far as where the power was gained and was there any losses at certain rpm?
Old Oct 27, 2012 | 10:46 PM
EvilTechnology's Avatar
Wow, forgot I started this thread. I'll go with S2's. Have one, just need to pick up the other.
Old Oct 28, 2012 | 03:32 PM
Spec-Ops1's Avatar
Stock head, no porting, supertech single springs, and stock valves... S2s picked up horsepower up top with the 2.4L
Silverton
21
Sep 7, 2019 02:13 PM
Jovan Caro
Feb 10, 2017 03:18 PM
Polish Stud
Mar 15, 2013 08:36 PM
roguedriver112
11
Oct 21, 2009 07:45 PM
IDRINKV8'S
Sep 15, 2008 09:33 AM
Quick Reply: Evo 8: JUN 272 vs S2, if cost was no issue
