Misfire and low boost reading
Man I ran into this problem today for the first time in my life, and wouldn't you know it would happen to me just two days before our Dynoflashing in Houston. My plugs are just like 1 1/2 week old NGK copper BPR8ES's, I know everyone is going to tell me that I need the Iridiums but plain and simple I can't afford them, I had the plugs gapped at .028 and got the misfire today so I took them down to .026 like I had my old BPR7ES's and it was running fine, but now my boost will only read up to 15psi no matter what I do with my mbc, which scares the hell out of me and I get the misfire in upper rpms, sometimes... It's like I have a boost leak somewhere, I am going to check the little crush fittings that came with my Autometer mechanical gauge tomorrow before I hit the road for Houston, the gauge was reading fine yesterday, then I had to reinstall it and I think one of those little brass crush fittings got messed up. Boy do I hope this is the problem. I know the mbc is good, it has always worked flawlessly and I checked all of my vacum lines and they looked to be in the same order that they always have. You know I really intended for the car to be in perfect working order for this weekend but leave it to my luck for some mystery problem to pop it's dirty little head up at the worst possible moment. Any suggestions?
So...why not put your old BPR7ES's in and see what happens? If the result changes in any way at least that points you in the right direction. Check all your hose clamps and if you have an aftermarket BOV that uses a flange (including 1G DSM) you may want to make sure the gasket is seated right.
Re: Misfire and low boost reading
68$ for a 30K car is not expensive
Well SuperchargedGTZ $68 for my current budget is too expensive, don't put that in my face man. Getting back to the intended topic, turns out the little crush washer that sealed the vac line to the fitting in that led to the gauge wasn't properly seated, easily fixed with a new one. Guys I can't even begin to describe the effects of my Dynoflash, OMG, Al is a true pro at this. I will do a write up or something to do justice to my excellent experience with Al this past Saturday but I have some college stuff to attend to for the better part of the day. Thank you Al and thank you to all who provided constructive feedback to my previous problem. Oh and btw my car was putting out rediculously low knock according to Al's knock link with 93 octane and my BPR8ES's.
TLeid91
Apr 4, 2016 07:43 AM
nikkonikko
Oct 23, 2011 06:24 AM
nytalonTSi
Oct 11, 2010 10:23 AM
