cosworth 272/272
Old Oct 23, 2012 | 02:36 PM
toozmok's Avatar
cosworth 272/272
Do you need to upgrade the valve springs if you have cossi m2 272 cams or would it be a waste of money?
Old Oct 23, 2012 | 03:51 PM
hosmer's Avatar
general consensus on 272's is stock springs are fine
Old Oct 23, 2012 | 04:16 PM
evo8426's Avatar
You can, but I wouldn't recommend it nor would I recommend running the engine past 7000rpm until doing the springs. Do it right the first time and save money and possible headache down the road.
Old Oct 23, 2012 | 10:27 PM
Bramage_Dained's Avatar
My car ran around with the M2s and stock springs for 3 years or so without issue, with the limiter set at 7500. A little over 50K miles were put on it during that time.
Im still running them on my current setup too, just with Buschur's Head/springs etc.
Old Oct 23, 2012 | 10:45 PM
EvlEvoIXSE's Avatar
i would recommend it did it on my car and definitely will benefit it down the line just my .02
Old Oct 23, 2012 | 11:14 PM
RoMeIX's Avatar
May as well just do it while you are putting the cams in.
Old Oct 24, 2012 | 02:02 AM
Ted B's Avatar
The stock springs will 'work' with any aftermarket cam set, just as the car will 'run' on cheaper, lower octane fuel.
Neither can be expected to deliver best power.
Old Oct 24, 2012 | 10:26 PM
toozmok's Avatar
so thats mean can use with stock valve spring?coz what i know if lift 11mm must use valva spring but can use stock retainer....
Old Oct 25, 2012 | 01:06 AM
Ted B's Avatar
Ia bermakna bahawa menggunakan spring asal tidak adalah idea yang baik.
Perhaps that will clarify things.
Old Oct 25, 2012 | 12:23 PM
wickedevo9's Avatar
I just did Cosworth M2 on mine with stock springs. So far so good. But I wish I wouldve spent another $200-$300 on springs and retainers.
Old Oct 25, 2012 | 12:56 PM
toozmok's Avatar
tq for ur language...i understand...what spring do u prefer?
Old Oct 25, 2012 | 12:58 PM
toozmok's Avatar
stock spring with m2?rev cut?
Old Oct 27, 2012 | 02:12 AM
JDM EVO 6's Avatar
i had 380 whp on pump with stock spring on m2
Old Oct 27, 2012 | 02:01 PM
todd6027's Avatar
id buy springs retainers and a different set of cams
Old Oct 27, 2012 | 06:54 PM
apagan01's Avatar
I did super tech springs and retainers when I did my M2s. I could have left the stockers in place
Quick Reply: cosworth 272/272
