Exhaust Manifold Stud Holes Stripped
I just searched through 10 pages and wasn't able to find the answers I am looking for.
I stripped out at least one exhaust manifold stud when I replaced my exhaust manifold. I re-tapped all the threads before installing new MAP exhaust manifold studs. I then torqued them down in the pattern, sequence, and specs mentioned in the FSM (finishing with: M8's @ 28 ft lbs, M10s @ 47ft lbs). Everything was fine until about a month or 2 later I noticed oil was leaking onto the exhaust manifold, when I went to re-torque the nuts at least one or two are stripped out.
My Questions are:
1. Do all exhaust manifold studs have an oil passage behind them? If not which do? Are some oil and some coolant?
2. If I drill out the hole to re-tap or use a helicoil kit, won't I get shavings into the oil passages ? Also need to break off the helicoil tab after installing it, wont that get into the oil passage as well? How do I prevent the shavings from getting into the oil passages, without having to remove the head?
3. What RTV do you use on the exhaust manifold studs, to prevent the oil from leaking through?
I plan on using a right angle air drill to drill out the holes. If I missed anything or if you have any other suggestions, please let me know.
Thanks,
My Questions are:
Thanks,
My Questions are:
Thanks,
My Questions are:
Thanks,
2)Yes. You need to remove the valve cover and oil pan to remove the debris you created. FWIW, you already created some when you tapped them in the first place.
3)High temp copper.
fostytou
338
Nov 10, 2023 11:55 AM
kozmic27
Evo X How Tos / Installations
32
Oct 28, 2019 04:39 PM
TakaseEVOIXSE
22
Feb 5, 2011 06:34 PM
TwistedEvo8
15
Oct 4, 2009 05:58 PM
