Can you align the steering wheel yourself?
Guest
So my mechanic unfortunately had to drop the rack and pinion to bring down my tranny. My tire alignment is perfect and untouched just now that my steering wheel is not centered, I noted under the steering column there is a socket looking thing that goes over the splined bar that goes to that rack and pinion. That has a pressure clip that you can remove and probably adjust the steering wheel yourself. Is that easier then it sounds?
At the bottom of the steering column. Where it meets the rack assembly. You can remove it, lift the yoke fitting off of the rack splines and move it left or right one spline at a time until the wheel is straight. Only move the column side. Be sure to have your car pointing straight ahead when you do it.
behind this cover is where the steering column meets the steering rack. You have to take the cover off to access that bolt. Loosen the bolt and then you can maneuver the steering column. I had to do this when I dropped my subframe for the tranny install. My steering wheel before was slight crooked, and now it's perfectly level.
edit: you can see the spline section on the rack in this picture. This part protrudes into the cabin and that is what the steering column slides on to.
Guest
rabbit61319
Feb 28, 2017 02:44 AM
rabbit61319
Dec 4, 2016 06:29 AM
gameapbt
Feb 2, 2016 01:35 PM
luckybull
Sep 19, 2013 12:19 PM
