How much PSI are you boosting?
I currently have Bushar intake and manaul boost controller set to 20.5 to 21 PSI. I peak at 21 and maintain 21 until about 6K then go down to 19PSI.
19 psi to redline (california 91 octane, with the occasional addition of some 100 octane)
buschur air filter, buschur tb, greddy profec B spec I...
uhhh on my friends car... yeah...
DAMN! You guys have *****, I am running at the most on my high map 19.5 to 20 psi max and for daily driving 18.5-19 psi with the stock head studs. I plan on replacing them this summer with my 264/272 cams. I run 93 oct daily and 110 every once and a while with the same settings just a leaner fuel map. 12.0 afr daily 10.5-11.0 afr.
1.84bar or 26.74psi (Vishnu Stage 1+ ) of course all this boost at 5400+ ft so it's really = ~22psi for you flatlanders My DSM with a 16g maxxed out at 22psi up here so this twin scroll 16 has some *****
I always run 93 octane. I'm running 20psi now. I'm in the process of installing a BR Stg 3. I'm hoping I can push 21-22 once I've got my ECU reflashed.
Ideally I'd like to get a datalogger so I can watch knock and timing. If you're not detonating and your A/F ratios are good, why not run as much boost as possible? Am I wrong?
