Oil squirter block off kit?
Hey guys I was tearing apart my motor today and unfortunately I broke the oil squirters banjo bolt. So I was wondering what the best option was to go with. Im going to so a piston and rod setup since my block has scratches on the walls. so should i buy a Block off kit or buy new ones? I'm kind of on a buying since I'm doing a full rebuild.
Thanks - Dain
Thanks - Dain
What I did in my talon way back in the day. Thing is though your oil pressure will still be kinda high. Depending if your motor has balance shafts (which my talon doesn't) you are gonna have to port the relieve valve some in your oil filter housing to keep the oil pressure down.
While on the subject, what WOT oil pressure would be considered too much?
poonpower
Nov 6, 2015 09:06 AM
