View Poll Results: Was this thread helpful?
Hell yes! Very useful for the community!
319
98.15%
No way, I still don't know what filter I need!
1.85%
Voters: 325. You may not vote on this poll
The OFFICIAL Oil Filter Testing and Results Thread (4G63T/4B11T)
#241
glad i'm understanding it correctly lol. there are pros and cons it seems though. just wish amsoil would tell me what damn EAO fits and what its bypass is set at. i think our cars (and most) can fit a way longer filter if we wanted to
#242
also can we get a damn spec sheet for all the AMSOIL oil filters? I swear it's impossible to get any info.. ie i was on ea15k09 on my corolla, discovered ea15k51 fit, and now discovered eao34 will fit
#243
You can try and reach out to my contact there:
Darryn Wallace
Sr. Technical Service Representative
AMSOIL INC.
ADDRESS: 1101 Susquehanna Avenue, Superior, WI 54880
E-MAIL: dwallace@amsoil.com
PHONE: 715-399-8324
FAX: 715-392-3097
#244
i'll give it a shot, thanks.
long *** belated update on this but:
i dont think pennzoil makes pennzoil ultra anymore at all - they make like platinum ultra, which is some sort of natural gas hybrid synthetic, not as good as the real thing.
i did do an oil test with PU on the Mini, not too much to gather from it though except that it ran pretty well and also it's on the thinner side of things slightly.
#245
That is annoying.
If you want to use one of these, look inside first, when you take it off the shelf, before buying.
I had this pic posted before, but somehow Image Shack "lost" it. So this time I wore my tin foil hat while re-uploading and re-posting. Posted both pics this time, only put up one pic before.
Anyway, look at the center tube to see if they still use louvers there instead of totally punched out holes. If it's got louvers like this one does, make sure they are open a decent amount. These you can see are mostly not open at all or are open only like a hairline crack.
At the time, I tried to get a spec from K&N on what the opening height should be. They could not or would not tell me. Haha.
A really poor thing about this is that if you installed a filter like this on your car, you probably wouldn't even notice anything was wrong. Just guessing here, but seems like it would just open the bypass valve - it would stay open all the time, your oil would be totally unfiltered. Nice thought hey?
At the time, it was the K&N HP-1008 & HP-1010, Mobil 1 M1-108 & M1-110 that were made this way (with louvers).
The one in the pics here is actually a HP-1003 which I had bought for my Toyota, so you Toyota guys take note also!
#248
I was surprised and impressed with their ability to filter within the context of my testing. I'm not a huge fan of the quality of construction, though. For the price and filtration, it's hands down the best of both worlds as far as I'm concerned.
#249
According to the info golgo got, the Bosch filters are made by Purolater, and I see some similarities in the specs.
Golgo tested the "distance plus" which is rated differently for "efficiency".
According to the Bosch web site, the Premium is rated 99% at 20 microns particle size, per ISO 4548-12. I like it that they give the efficiency at 20 microns, because in my opinion, this is the best particle size to be talking about, and 99% is very high for this size particle, and since they give you the ISO test #, you could possibly check that out if you are curious about it.
For the "Distance Plus" and the "Long Life" they say 99.9% and 99.5% respectively, both at 40 microns. In my opinion, they should be talking about 20 microns, not 40 microns. So these 40 micron ratings leave me a little cold.
Also the Distance Plus and Long Life seem to be geared for long oil change intervals, which most of us probably don't give a hoot about.
I would imagine the "Premium" has the same poor construction quality that golgo observed. I haven't taken mine apart to look.
#250
Bosch | |
Manufacturer: | Purolator |
Part Number: | D3323 |
Media Type: | Cellulose + Synthetic Blend |
Micron Rating: | 30μm Nominal |
By-pass Valve Rating: | 14-18psi |
Flow Rate: | 9-11gpm |
Burst Pressure: | 500psi |
Media Surface Area: | 64sq in |
Pleat Count: | 53 |
Drain Back Value Material: | Silicone |
Country of Manufacture: | USA |
Nominal vs. Absolute Filtration:
A filter is considered nominally efficient at a certain micron level if it can remove 50 percent of particles that size. In other words, a filter that will consistently remove 50% of particles 20μm or larger is nominally efficient at 20μm.
A filter is considered to achieve absolute filtration efficiency at a certain micron level if it can remove 98.7% of particles that size. So, if a filter can remove 98.7% of particles 20μm or larger, it achieves absolute efficiency at that micron level.
#251
The ratings I gave would all be "absolute" as I understand it, because they were all 99% or higher. So, 20 micron absolute then, for the Premium.
Yeah if the 30 micron rating is only "Nominal", that seems pretty lousy.
That's why I'm suspicious of the 40 micron ratings they give. Because even though it is 40 microns absolute, if they are only "Nominal" at 30 microns, think what they might be at 20 microns! Ouch!
#252
<<<@!1!@>>>
I could probably forget all about these crummy filters and go electric if they would equip every electric car with 3 kooky girls like the one in this video.
Seohyun driving here, 720HD video:
Last edited by Talonboost; Nov 4, 2014 at 01:18 PM. Reason: Problems with the non-official TaeTiSeo videos, so I replaced with one from the On Style YouTube channel.
#254
Oh gee sorry - yep that's really my post. I get lots of smiles from that kind of stuff, hope you enjoy. Listen to how they say "side brake" - oops, side brake is not in this segment.
