Cams. Tomei vs Kelford
https://www.evolutionm.net/forums/ev...0whp-40tq.html
I'll be putting Tomei 270s in my VIII soon. The lift is quiet a bit higher than the Kelford 272s.
What's your other mods?
i have manley stroker 2.2. kelford cams. map O2 downpipe and blitz nur spec r cat-back. i decide to be with kelford! But i need your help in transmission. i have 5 speed 9RS transmission. but it is very short. when i have race with the same evo . i loss the race. first 4 speeds are great. but when i switch from 4 to 5 speed i have a chasm between these speeds. so ,what should i do??? may be 5 speed GSR??? or VR4 transmission?
Something tells me you didn't read the post and immediately went for the biased "Kelford 272 or S2" approach. There are other proven cams, not everyone want the cookie cutter modded Evo.
To the OP, the 5 speed does have a long 5th gear that doesn't match with 1-4 but in a drag race, you only need 1-4 until you start trapping 125-140mph depending on your shift point.
lol I thought the same thing when I read his post. To the op, start with the ams cam thread to start getting your head around what does what..
