Replacing the battery with a smaller one to fit a custom intercooler pipe
I agree. Trunking it really cleans up the engine compartment and gives you a lot more room to work with. Not to mention moving all that weight just ahead of the rear tires.
I have the 680 (under my pass. seat).
I just had to get a jump start. (which was kinda cool testing the jump-ability of my set-up).
My car has set for a month, then started about 6-8 times and only run at idle for 2-3 mins, (I was installing an EGT).
I drove it for 2 miles, shut it off. When I tried to start it,"click, click, click".
It jumped fine.
I have a battery tender hooked to it now.
I may re-consider the stock battery moved to the trunk.
It jumped fine.
I got the 680MJ for 90 delivered off of eBay with SAE terminals.
Originally posted by Guru_Del
agreed it is cleaner however all the tracks out here in California require you to have an exterior cut off switch if you have a relocated battery.
the rules say it has to be accessible from the outside, in the rear of the vehicle. i head a suggestion of putting it in the trunk and then taking the trunk lid off when racing hahah....
pepboys, kragen, buschur, etc.
They are pretty universal but i think BR actually has one that includes the small battery. I could be wrong as I often am. I used the pepboys one, included wire, hold down and tray.
EVO8speed
26
Dec 18, 2009 08:43 AM
