pulling motor!
pulling motor!
Hey guys question for you. Im about ready to pull my motor. Everything is off and ready. My question is can u pull the block while leaving tranny in car?? I cant figure it out lol lmk thanks
The way I did it I pulled it out with tranny and it was super easy especially if you have the engine leveler, but I was told that you can pull it without it and easier is to just drop it.
Streetsweeper (Sep 8, 2019)
i guess i should have scrolled down two quotes
I have done it several different ways, but if I had a lift I would probably drop the whole thing out the bottom with the subframe as mentioned. Working on the whole lump is easy that way, and ingress and egress is much simpler. Wrestling with the tcase and space can be a pita.
I pulled the trans and engine out separately but then installed as one piece. I would at least take out the trans and engine together if doing it in my garage again.
On a separate note if I were doing anything with the tcase again I would drop the subframe. It makes everything so much Easters just with a few extra steps. Now that I have done the subframe I wish I would have listened to folks that told me to drop it for a clutch job. Working the tcase without the subframe makes it soon much easier. Especially without a lift.
Dropped mine out the bottom in 4 hours taking 3 breaks. Power searing lines ac conpressor engine mount tranny mount driveshaft wiring harness control arms and tie rods if you wanna leave the the suspension in. Thats basically it. I might be missing a few things since mines so heavily modded.
Ya so far im into it around 4 hrs! This is my first time. but i also deleted a bunch of things while taking **** out. Now today just gonna drop everything out the bottom. And new engine is going in next week when its done thanks for the help guys.
AutoXMRIX
Jan 2, 2017 07:22 PM
theblackbeast11
Oct 16, 2015 04:07 AM
