coverting MAF to IAT
Hey guys so I tried doing some searching real fast I won't lie. Im not to educated on wiring and such so my question is since im going to run a map sensor can I use my MAF sensor wires for my IAT sensor that im going to be running. if so please explain! Thanks!
Someone has a kit that actually uses the MAF harness to send AIT signals to the ECU. Plug-n-Play too. You just have to flash a Tephra mod and change some values, that's it.
*edit* Spoolin Performance makes the kit. www.spoolinup.com
