Evo 4g64 oil pump help
Old Feb 9, 2013 | 05:43 PM
evoboy2006's Avatar
Hey guys I was in the process of puting my 2.4 motor together I currently brought brand new 4g63 oil pump as I put it on the block I noticed where the alternator goes the oil pump don't line up with the block any help do I need to buy a 4g64 oil pump thanks guys
Old Feb 9, 2013 | 08:58 PM
2006GSR's Avatar
Pictures would be helpful.
Old Feb 10, 2013 | 07:11 AM
evoboy2006's Avatar
Here is pic man
Old Feb 10, 2013 | 07:36 AM
ExViTermini's Avatar
That block won't fit an evo...there are a few diff 4g64 blocks. You need the one that has the dip in on the oil pan surface for the xfer case. Most of the accessory brackets won't fit that block either.....sorry.
Old Feb 10, 2013 | 08:38 AM
2006GSR's Avatar
You need 00-03 (some 04) Galant, Outlander, and Eclipse for the 4g64 engine. The one you have is the wrong one. The trans has to be on the drivers side.
Old Feb 10, 2013 | 09:03 AM
evoboy2006's Avatar
So this block is for a dsm correct?
Old Feb 10, 2013 | 09:32 AM
VIIIdriver's Avatar
Looks like it is, previous generations 4G64 were positioned on the left (driver) side of the car, the newer generations were on the right side which means the block is almost the same but all the accessories are in the wrong place, the block you need would have to come from a Galant 99-03, Eclipse 00-04, good thing is you can find them pretty cheap, i bought a whole engine for $350.00 for my build.
Old Feb 10, 2013 | 11:47 AM
evoboy2006's Avatar
Anyone else have input? Thanks guys
Old Feb 10, 2013 | 07:57 PM
Murf's Avatar
Wrong 4g64 block
Old Feb 11, 2013 | 11:12 AM
JohnBradley's Avatar
DSM block. Block stamp is not next to the dipstick on an "evo style" block. Stamp is on the front and the dipstick is on the back.
benIX
26
Feb 4, 2022 05:36 AM
benIX
Nov 26, 2016 08:58 AM
benIX
Oct 6, 2016 04:48 PM
05EV08
15
Jul 26, 2016 09:28 AM
300zxhks
Nov 9, 2012 07:15 PM
