need some help on p0365 code
This codes is on a 2006 evo 9 mr code appeared after a cam swap.
cams are hks 272's for the mivec
p0365 is the intake cam sensor code per the mits dealer
So far I have installed a new oem sensor part no. MR507814 (with the white dot just like the old one) code still comes up.
code wont show up the first time i crank it and can drive it forever and never show. but if i cut it off and back on it comes back. also the simple test of starting it and leting it run for 30 secs then turning it off and back on code comes up.
the big kicker to this is that when i use 2 exhaust cam sensor the light stays out.
all my timing marks line up and the sensor is tight intake can only gone oneway.
any one have any ideals on the issue? havent went as far as using a scope on it since i dont know what a good or bad wave form would look like for this sensor
sebass007
Lancer How Tos / Installations
40
Dec 28, 2020 08:20 AM
Woostopher
Aug 17, 2017 10:57 AM
